» marca de bóia do tamque
35 usuários online :: 2 usuários cadastrados, Nenhum Invisível e 33 Visitantes :: 2 Motores de busca
cintras, hittokiri
Novo Projeto
Beto
Modelo do carro : To Sem Carro
Data de inscrição : 15/02/2009
Novo Projeto
Mensagem por Beto em Ter 27 Jul - 12:17:25
Seguinte galera to querendo montar um negócio razoável no meu coupe o Cd eu já tenho assim como as 2 D-250X, mas no caso de apenas 1 Sub eu vou usar apenas uma D-250X seguem os itens
Meu cd Premier DEH-P880PRS
Especificações
Supertuner (AM/FM Radio)
Supertuner Supertuner IIID
24-Station/6-Button (18FM/6AM) Presets
BSM (Best Stations Memory)
Local Station Setting Selectable (4-Step)
Satellite Radio Capability
XM Radio Ready Yes (GEX-P920XM Required)
Sirius Radio Ready Yes (SIR-PNR2 Required)
CD Player
1-bit D/A Converter 24-bit Burr Brown
CD-R/CD-RW Compatible
AGC (Automatic Gain Control)
Disc Title Memory
Disc List
Track Title List
CD Text CD Text
MP3 Playback Compatibility
Codec Support MP3, WMA, WAV, iTunes AAC
File System ISO9660-1,-2, Romeo, Joliet
Max Directory 8
Max. Folder # 99
Max File # per Disc 999
Multisession Disc Play
Random Play Folder/Disc
Repeat Play File/Folder
MP3 Bit Rate 8~320kbps or VBR
WMA Format WMA v7, 8, 9, 10
WMA Bit Rate 48~384kbps, VBR
AAC Format iTunes AAC
AAC Bit Rate 16~320kbps
File Name 64 bytes
Folder Name 64 bytes
ID3/WMA Tag ID3 v1.0, 1.1, 2.2, 2.3, 2.4; WMA; iTunes AAC
Tag Length 64 bytes
Tag Data Track, Artist, Album, Comment
Tag Display On/Off
List Search File and Folder
iPod Control Capability
iPod Control Capability Adapter (CD-IB100II required)
Additional System Expandability
IP-Bus System Control
Multi-CD Control
DVD Control
TV Tuner Control
Display Output
Built-in Auxiliary Input Built-In (Rear)
Optional (IP-Bus) Auxilary Input CD-RB10 or CD-RB20 required
External Unit Control 2
Display Features
Face Type Flap Face
Motorization Auto Slide Motorized
Display Type White Organic EL (OEL)
Dot Matrix OEL Size 160 x 48
Multi-Language English, French, Spanish
Button (Key) Illumination Switchable Blue or White
Audio Features
Built-in Speaker Power MOSFET 50W x 4
Continuous Power Output 22W x 4
Equalizer Dual (L/R) 16-Band Graphic
Equalizer Presets 5
User Equalizer Settings 2
Loudness Yes
DSP
Auto-EQ (With Mic Included)
Auto-Time Alignment
Listening Position Selector
BBE Digital
Electronic Balance/Fader
Source Level Adjuster (SLA)
Crossover Network 3-Way Crossover
High-Pass Crossover (HPF) 50/63/80/100/ 125/160/200Hz, 0/-6/-12dB/Oct.
Subwoofer Crossover (LPF) 50/63/80/100/ 125/160/200Hz, -6/-12/-18dB/Oct.
RCA Preouts 3 pair (Front, Rear, Sub/Non-Fading)
Preout Voltage & Impedance Hi-Volt (5V), 100 ohm
General Features
Volume Control Rotary Volume
Operation Mode Rotary Commander
BRAVOX CS60U
OU DA MTX
ESPECIFICAÇÃO
Kicker Modelo CVR12 400RMS
Tamanho (pol, CM) 12, 30,5
Impedância (OHMS) 2 ou 4 DVC
Rec. Amplificador Max Power (WATTS PEAK / RMS) * 800/400
Sensibilidade (1W/1m dB) 86,7
Resposta de Freqüência (Hz) 25-500
Profundidade de montagem (pol., CM) 6 5 / 16, 16,1
Mounting Cutout (pol., CM) 11 1 / 8, 28,3
Min Rec. Sealed Box Volume (cu. FT., Litros) 1, 28,3
Max Rec. Sealed Box Volume (cu. FT., Litros) 4,6, 130
Min Rec. Vented box volume (cu. ft., Litros) ** 1,75, 49,6
Max Volume Rec. Vented Box (cu. ft., Litros) ** 2,25, 63,7
ESPECIFICAÇÕES
MTX SUB TR5512-04 400 RMS
Cone de polipropileno
Costurados nitrile-butileno borracha surround
Carimbada aço cesta
Poder manipulação: 200-400 watts RMS
Potência de pico manipulação: 800 watts
Sensibilidade: 86,6 dB
Top-mount profundidade: 6-3/4 "
Caixa selada volume: 1.25 cu. ft
Portado Volume: 2.0 cu. ft
ESPECIFICAÇÂO
# Tamanho 12"
# Potencia Max: 1400 W
# Potencia Nominal: 400 W
# Cone IMPP reforçado de fibras entrelaçadas de basalto/carbono para baixos mais natural
# Bobina de voz longa de 4 camadas de cobre
# Borda radial com rolo largo de três camadas (2 camadas de urethane com uma camada de fibra interligada entre eles)
# Imã poderoso de massa duplo (83oz) para mais força magnética e música maior e mais exata
# Bobina de Voz de vidro revestiu de phenol resin
# Conjunto magnético com pólo estendido e ventilado
# Abafador de Fibras de Aramid
# Cesta selada com cobertura para o ímã
# Terminais de Compressão prateados de um só lado integrados
ESSE MÓDULO PARA O SUB
ESPECIFICAÇÃO
  • 1200W Monoblock Amplifier, High/Low X-over, Remote Sub Level Control
  • 2 Ohm Stable Mono-Block
  • Variable low pass crossover: 40-150Hz
  • Fixed high pass crossover (200Hz)
  • Variable 0 to +18dB Bass Boost
  • Variable input gain control
  • Power and protection LED indicators
  • Thermal, overload and speaker short protection
  • Line and speaker level inputs
  • Chrome plated RCA connectors and screw terminals
  • Remote subwoofer level control
  • Frequency response: 9Hz - 50kHz (+/- 3dB)
  • Max power 2 ohm 1200W X 1
  • RMS power 4 ohm 500W X 1
  • Signal-to-noise ratio 103dB
  • THD at RMS output 0.01%
  • Damping factor 125+
  • Dimensions (9-1/8" L x 10" W x 2-7/16" H)
ESSE PARA CORNETAS
ESPECIFICAÇÕES
  • Low pass crossover on CH3/4: 120Hz (fixed, 120Hz)
  • Frequency response: 12Hz - 22kHz (+/- 3dB)
  • Max power 2 ohm 100W X 4
  • RMS power 4 ohm 50W X 4
  • Signal-to-noise ratio 90dB
Dimensions (7-5/8" L x 9" W x 2-1/16" H)
Seguem os Preços em DOLAR
Subs
CVR12-4DVC 90.00
TR5512-04 115.00
TSW 308D2 63.00
MODULO SSL F4-400 400W 4CHANEEL 38,30
MODULO SSL F1200M 1200W DIGITAL 59,47
Agora é que começa minhas dúvidas quero um sub pra muito grave sei que os MTX são excelentes para Sub Gave só que o preço está acima dos Kickers, e o Pionner tá compreço excelente dá até pra colocar 2 ao invés de um MTX ou o Kicker e tambem aproveitaria pra colocar minha outra corneta que vai ficar parada, só que teria que partir pra um outro módulo cado montasse para 2 subs,agora fiquei impressionado com esse video sendo que os falantes Sony não são muito bons para grave mas esse me surpreendeu e muito
gostaria da opinião da galera sobre meu projeto
Gabriel Coelho
Re: Novo Projeto
Mensagem por Gabriel Coelho em Sex 30 Jul - 13:44:42
Vc tem um player EXCELENTE nas mãos! ótimo mesmo! com TA, 3way... um dos melhores players que a pioneer já lançou, sem dúvidas!
quanto aos subs, EU iria de MTX, pq gosto de subgrave monstro mesmo, deep low bass! os pioneer não me agradam o timbre! muito artificiais! o MTX é um pouquinho melhor... um MTX muito bom é aquele 5500 quadrado! tem um SPL BEM alto, desce bem, e tem um timbre gostoso de se ouvir!
se quiser mais musicalidade, dai vai de UXP ou 2xPanther 10" (eu iria de 2 pantherzinho de 10")
mais a noite eu leio o resto do projeto e dou uns pitácos!
Beto
Re: Novo Projeto
Mensagem por Beto em Sex 30 Jul - 19:11:39
Então Gabriel eu sei que MTX é top para Subgrave, tem esse
Por 10 dolares a mais
12 "4-ohm bobina dupla subwoofer
Butadieno borracha nitrílica surround
Carimbada aço cesta
Poder manipulação: 300-600 watts RMS
Potência de pico manipulação: 1.200 watts
Frequência de resposta: 31-150 Hz
Sensibilidade: 87,6 dB
Top-mount profundidade: 6-15/16 "
Esse Phanter eu não conhecia, mas pelo preço que eu acabei de ver prefiro um MTX, quanto ao UXP é muito caro com o preço de 1 eu compro 2 MTX como o outro ou 1 desse acima ou o 2 Kicker e ainda sobra dinheiro pro módulo stéreo e com certeza teria um ganho muito maior do que com o UXP, o que tá pesando na minha decisão é que são muitas opções de Sub por preços praticamente equivalentes e o Módulo que eu pretendo usar para o sub casa perfeito pra qualquer desses de 4 ohm por saber que esses SSL mentem na potencia então se ele fala que dá 500 em 4ohm, ele dá no máximo uns 380-400(é o que eu espero) agora em 2ohm se der 800 já é um lucro do caramba pelo custo desse módulo.
QUAL A DIFERENCIA DE RENDIMENTO DESSES QUADRADOS PARA OS FALANTES REDONTOS
Pois tem uns kickers que partem dos 250 dolares e uns mtx tambm
Gabriel Coelho
Re: Novo Projeto
Mensagem por Gabriel Coelho em Sex 30 Jul - 19:50:41
Beto escreveu:Então Gabriel eu sei que MTX é top para Subgrave, tem esse
Carimbada aço cesta
então, o cone quadrado tem maior área que o redondo, por isso o SPL costuma ser maior (mais sensibilidade)... fora isso é estética mesmo! o MTX de 12" tem mais de 90dB de sensibilidade, contra uns 86 do "irmão" redondo dele! isso é MUITA coisa!
se vc pretende ouvir musicas com grave muito rapido (metal por exemplo) TODOS esses subs tendem a embolar (pioneer e kicker pior q o MTX), o kicker é um sub duro e que não desce muito, mas tem ótimo SPL, o MTX não sobe tão bem, é show pra hip hop, mas num Psy por exemplo ele ja não toca tão bem, mas é parrudo e aguenta potencia tranquilo! O pioneer é aquele faz tudo, ele tem um subgrave mais ou menos, um SPL bom, um timbre meio "cinza" pra tudo, toca de tudo mas não se destaca em nada... não sou fã
o Panther deve ta em torno de 180 reais cada um de 10", são subzinhos pra tocar de 30Hz pra cima MUITO planos, são rápidos e tem um timbre corretísiimo, são, na minha opinião, os melhores subs nacionais para quem busca qualidade! mas por serem planos demais não agradam quem gosta de um pico nos graves!
o UXP realmente custa mais do que toca! mas é um ótimo sub tbem, assim como os NAR SW3, outros caríssimos... tudo culpa de impostos... Brasilzão é assim!
esse amp SSL realmente não é um sonho não, é um chinezão genérico, mas é fortezinho sim! dá pro gasto!
vc vai usar o amp para o kit e para os drivers... dê um jeito de desligar as cornetas (chavinha lá atras, na mala) enquanto vc estiver de mala fechada! vc já tem as cornetas ai, então usa, mas se fosse montar um "mini trio" do zero iria de PW3 de 8" e ST200
quanto ao kit bravox, é um excelente custo X benefício! Melhor que o de entrada da MTX! fique com o bravox!
quando se decidir no sub me avisa que eu faço o projeto de caixa pra vc!
abraço
Beto
Re: Novo Projeto
Mensagem por Beto em Sab 31 Jul - 20:50:31
Gabriel Coelho escreveu:
abraço
Então mano a questão de trio está fora totalmente de cogitação eu tava aqui com uma caixa com 2 de 15 da Khonnus Voicer(300rms cada) vendi justamente pra montar outro som, quanto ao uso das cornetas eu to com intenção de usálas mas como vc falou ligar elas só quando for abrir a mala ou virar ela pra cima dentro do porta malas pois não vai ter nada de falantes atrás, mas isso só depois de pronto mesmo pra ver, quanto a esses Phanter eu não conhecia o preço deles é 10 R$180,00 de 12 R$212,00 só que por esse preço dá pra eu comprar esse ultimo MTX, quadrado e de 600rms, o preço de 1 UXP eu compro 2 MTX então está totalmente fora de questão, quanto aos SSL eu vou neles pelo custoXbeneficio, sei que eles não entregam tudo o que falam, mas pro que eu to querendo fazer vai se encaixar perfeitamente, pois ele tem controle para Sub e meu cd tambm tem uma saida só pra sub, então a perca que ele tiver esses recursos vão suprir perfeitamente, ligando a saida sub pro módulo D e as outras duas saidas F e R no outro para corneta e mid, um bom player faz muita diferença nessas horas, eu paguei uma mixaria por esse e já me ofereceram bastante por ele
Gostei do grave desses subs da Sony ainda mais por eles serem mais Voicer do que pra SPL ou Sub
Beto
Re: Novo Projeto
Mensagem por Beto em Sab 7 Ago - 15:46:25
Vou mesmo nesses 2 SSL cotei hoje e houve mudança nos preços
MODULO SSL F4-400 400W 4CHANEEL 43,00
MODULO SSL F1200M 1200W DIGITAL 92,00
Quanot aos falentes eu vou de 2 308D2 pois o MTX TS5512 tá em falta e pra pegar o TR5512-04 não vejo vantagem uma por ser 4ohm e outra pelo preço de 1 eu compro 2 308D2 que vai dar um ganho bem maior
Quanto a caixa tava vendo em uma 52L pra cada com duto de 4x28
ricardo rick
4cil
Re: Novo Projeto
Mensagem por ricardo rick em Ter 31 Maio - 14:39:38
caro opaleiro gabriel coelho
como vc é estalor me de uma força ai tenho comodorom90 4portas
com seguintes equipamentos pioneer DEH-P5000 2coaxial bravox 6" 45wts
2 6x9 HX 75wts 1subwoofer extreme selenium 12" 650wts(antigo vermelho)
modolos pro sub stetson 1k5 1800wts esterio SSL 4.400 400wts a caixa tem 50ltr com dois dutos um em cima e outro de lado que vc acha ta bm me de uma força ai obrigado
Re: Novo Projeto
    Data/hora atual: Dom 24 Jun - 22:39:43
