63 usuários online :: 2 usuários cadastrados, Nenhum Invisível e 61 Visitantes :: 1 Motor de busca
Müller, Victor fedalto bora
White Super Bright Cheap Auto Bulb Lamp
Aliyazhu
Feminino Número de Mensagens : 3
Data de inscrição : 17/11/2012
Mensagem por Aliyazhu em Sab 17 Nov - 1:12:10
Hi,everyone,I want to introduce you a hottest products:
This L.E.D. Light has 5050 SMD. chips. Durable, shock and vibration proof, instant On/Off. Easy installed. Just plug and play.It can be used for Tail light, Instrument Cluster Lights, Under hood light, Dash Lights, Dome Lights, Map Lights, License Plate Lights, Reverse Lights, Parking Lights etc.
Features:
1.1 pcs
2.Base: T10
3.Weight: <50g
4.Input Voltage:12v
5.Defective rate: 0.1%
6.Light Chip: 5050 smd
7.Base Material: Plastic
8.Popularity index: 5 star
9.Lifetime span: 50.000 Hour
10. Power consumption: 1.5w
11.Currency:0.11±0.1mA
12.Viewing angle:360 degree
13.Brightness efficiency: 135±5 lumen
14.Operating Temperature: -30-75℃
15.package size: 10.8*6.3*1.7cm
If you have any questions,please email:contact at lion-leds.com
Re: White Super Bright Cheap Auto Bulb Lamp
Mensagem por wyllerson punk em Sab 17 Nov - 4:43:06
we speak english....
we dont undertand nothing.
we are jumentos..
very jumentos
luciano76
Cilindros : 4c
8c
Mensagem por luciano76 em Sab 17 Nov - 5:35:25
wyllerson punk escreveu:we speak english....
we are jumentos..
very jumentos
O will desse jeito vc burn our movie,
mas ri pakas!!!!
Ghost
Mensagem por Ghost em Sab 17 Nov - 10:08:13
Aliyazhu escreveu:Hi,everyone,I want to introduce you a hottest products:
Features:
1.1 pcs
2.Base: T10
3.Weight: <50g
4.Input Voltage:12v
Do you have any other item type or only leds?
Make your text and put in one translator and post here back ... 95% of ppl here don't speak english ...
Vendidos:
leandro 4cc
ex caravan comodoro 80 4cc
Mensagem por leandro 4cc em Sab 17 Nov - 10:09:52
por favor aperte a tecla SAP....
Mensagem por BANDIT em Sab 17 Nov - 10:11:41
Isso é globalização !!!!
Um Chines postando em ingles......num site brasileiro.....de um carro com carroceria alemã .....mecânica americana.....montado no Brasil.........confused
pézão opaleiro
Cilindros : 0
Mensagem por pézão opaleiro em Sab 17 Nov - 10:26:41
cara que loucura affraid
Pablo Fernandes
Masculino Número de Mensagens : 236
Modelo do carro :
Opala Std 1976
Data de inscrição : 14/01/2012
Mensagem por Pablo Fernandes em Sab 17 Nov - 10:33:49
traduzindo....
Oi, todos, eu quero te apresentar um produtos mais quentes:
Este L.E.D. A luz tem 5050 SMD. chips. Choque, durável e à prova de vibração, Instant On / Off. Fácil instalado. Basta ligar e play.It pode ser usado para a cauda de luz, luzes de painel de instrumentos, sob luz capô, luzes de traço, luzes de abóbada, luzes de mapa, luzes de placa, luzes Reversa, luzes de estacionamento, etc
características:
1,1 pcs
2.Base: T10
3.Weight: <50g
4.Input Tensão: 12v
Taxa 5.Defective: 0,1%
Chip 6.Light: 5050 SMD
Material de 7.Base: Plástico
Índice 8.Popularity: 5 star
Extensão 9.Lifetime: 50,000 Hora
10. Consumo de energia: 1.5W
11.Currency: 0,11 ± 0,1 mA
12.Viewing ângulo: 360 graus
Eficiência 13.Brightness: 135 ± 5 lúmen
14.Operating Temperatura:-30-75A ƒ "
15.package tamanho: 10.8 * 6.3 * 1.7cm
Se você tiver alguma dúvida, por favor, e-mail: contato em leão-leds.com
Mensagem por Diegoj em Dom 18 Nov - 13:38:37
Isso ai provavelmente é bot, tem alguns foruns que tao cheio dessas pragas. Criam 500 cadastros e ficam postando automaticamente propagandas de tudo que é porcaria.
Aposto que essa vai ser a primeira e a ultima postagem desse usuario, não vai nem responder mais aqui. Ai daqui uns tempos aparece outro cadastro assim fazendo propaganda de outra coisa.
Raphael Manenti
Masculino Número de Mensagens : 1247
Modelo do carro : 1979 Opala 2p
Mensagem por Raphael Manenti em Dom 18 Nov - 13:52:48
Features:
1.1 pcs
2.Base: T10
3.Weight: <50g
4.Input Voltage:12v
How much does it cost?
How long to delivery in Brazil?
Does it have garantee?
What is the minimum quantity for an order?
Traduzindo:
Quanto custa isso?
Quanto tempo apra entregar no Brasil?
Isto tem garantia(não custa perguntar né..rsrs)
Qual a quantidade mínima para um pedido?
Aliyazhu
Mensagem por Aliyazhu em Dom 18 Nov - 20:21:23
CarlosSchenckel escreveu:
Features:
1.1 pcs
2.Base: T10
3.Weight: <50g
4.Input Voltage:12v
Hi,thanks for your advice,we have many type,would you please let me know your email address?Then i will send different types to you and the price lists.
Aliyazhu
Mensagem por Aliyazhu em Dom 18 Nov - 20:28:21
Raphael Manenti escreveu:
Features:
1.1 pcs
2.Base: T10
3.Weight: <50g
4.Input Voltage:12v
Traduzindo:
Quanto custa isso?
Hi,thanks for your inquiry.
1)The price is 0.98usd,our price is depends on the quantity,if your order is big,we will offer you the best price.
2)The goods can be sent to you in about 5-7 business days.
3)All of our products have garantee.
4)The minimum quantity is 10 pcs,or you can send your quantity,then we will try our best to offer you.
would you please send me your email address?Then i will send you our price lists?Any question,please feel free to email:contact@lion-leds.com
Luis_555
Mensagem por Luis_555 em Seg 19 Nov - 10:16:46
nicolas opaleiro
Mensagem por nicolas opaleiro em Seg 19 Nov - 10:42:11
ri que chorei do wyll ahuahuahuaha
Raphael Manenti
Mensagem por Raphael Manenti em Seg 19 Nov - 11:06:38
Luis_555 escreveu:
Te book is on the table..kkkkkkk
Mensagem por frederico santos em Seg 19 Nov - 15:26:16
Pra que essa porqueira?se fosse pelo menos algum produto interessante...será que é mulher queen ou um traveco? rendeer
Opalamor
Idade : 47
Modelo do carro : Coupe 1976
Cilindros : 6 Bocas - 250S
Mensagem por Opalamor em Ter 20 Nov - 6:48:34
Hi...
The dog nhec nhec my pernetion!!!
Do you spits or swallows...???
Bye.
Sr.Bianchi
Bmw E36 coupé 328I
Ford F-250 4x4
Cilindros : 6+6+4
Mensagem por Sr.Bianchi em Ter 20 Nov - 7:47:18
E eu achava fantástico quando os coreano vinham vender tênis a preço de banana em casa...
Agora você acessa as redes sociais (qual é, esse forum é rede social também, se não eu um cara moderno e cool não tava aqui) e alguém da China lhe oferece Super white light bright mother******* Leds bulb lights bright bruce lee, tipo...tu não precisa nem pesquisar... eu acho isso fantástico.
Mas escuta nego(a) véio(a), if just in case you got some really nice good quality v8 engines sitting around for sale at really, really, but like... super affordable price, please, be a pal and let us all know about it.
Also, I've heard that the guys from golclub, golquadrado, clubeap, clubedoapturbo forums go absolutely mad ond L.E.D stuff, 'cause they sort of love tunnig, so you may want to put some ads there as well. And put just as many as you want, they really seem to be reciprocal on new products advertisement.
Whish you great deals.
Wink
Xis
Masculino Número de Mensagens : 315
Modelo do carro : Chepala 2.8
Data de inscrição : 29/09/2011
Mensagem por Xis em Ter 20 Nov - 8:08:05
hahahahahaha...
Sr Bianchi mandou bem...deixa nossos amigos de goletas apezeiros serem atormentados...kkkk
Raphael Manenti
Mensagem por Raphael Manenti em Ter 20 Nov - 11:22:25
Xis escreveu:hahahahahaha...
Muito bom Sr. Bianchi.... Very good....rsrsrsrs
    Data/hora atual: Ter 19 Jun - 18:12:21
